Posted By AutoEAC on 07/17/2008 6:06 PM [b]I am considering 26 ga steel sips for the roof of my building and have some questions.
Can they be walked on or will they dent easy? What is the typical roofing material used as covering? The underside will not be covered and as I understand are white. Is this a matte finish or gloss and how are the acoustics? Finally does anyone have first hand experience living with this type roof on a long term basis? Pros and Cons.
AutoEAC[/b] AutoEAC,
They don't dent easily, but they will dent.
we use all types of roofing following shows shingles going on
http://southernsips.com/job_hudson.html
I have lived in one for 7 years and another for 4 years , my opinion is biased
accoustics are similar to frame construction, they still get drywall on the inside, carpet on floors , etc.
DONALDSONs posts are from an owners perspective
finish is as shown in picture attached
the PROs are as follows
Although any SIP construction will save 50 – 60% in energy costs, are 3 times stronger than frame, and are more environmentally friendly. Steel is a better choice for the following reasons
Advantages of Steel SIPs vs.OSB
v Steel will not warp, swell, twist, rot
v Rain during construction do not affect materials in any way
v No cranes needed for installation a steel SIPs are lighter than OSB
v The underside of the roof panel automatically forms an attractive finished soffit overhang or exterior porch ceiling.
v Joints are a T&G friction fit they do not require splines, mastic or fasteners greatly speeding installation time
v Steel is more stable during manufacturing and panels are held to 1/16” tolerance
v OSB is limited to 24ft. in length …Steel SIPs are available up to 53ft. in length, eliminating butt joints
v Steel panels are manufactured on a continuous line making them available in square pre-cut lengths in ¼ ” increments, but only charged to the nearest ½ ft., OSB often rounds up to the nearest 2 ft. increment – making you pay for waste that gets thrown away
v Higher ” R – Value” denser foam provides a 4.25 R- value per inch of foam
v No Termites … Impervious to termites and carpenter ants , foam core is borate treated
v No foam grooving is required for window and door openings, after cutouts are made, openings are simply “picture framed” with 18.ga. steel channels
v The steel skin is the “vapor barrier” on walls no additional covering is required before siding is applied
v Eave overhangs can be 4 feet with no additional support
v Sound Control – utilizing a 1-1/2” steel furring strip creates a dead air space for improved STC ratings.
v Wiring – utilizing that same air space, wiring is much easier than fishing wire thru OSB and any future retrofit wiring is easier.
v Will not support mold growth – painted galvalume steel skins are UDSA approved
v Indoor air quality is better due to the tighter and cleaner construction material of the interior
v Any steel building is safer from lightning strikes
v “Monocoque construction” All connections and attachments are with screws having greater pullout strength than nailing
v For economy or insulated utility buildings, steel SIPs have been left exposed as the finished siding and roofing.
v Zurich Ins. In partnership with the Steel Framing Alliance offer reduced builders risk insurance premiums
v In Florida and other hurricane prone regions Steel SIPs are 30% less to insure that block/truss and 53% less to insure than wood frame construction
