Posted By JBS on 09/02/2008 2:17 PM
The connection detail at the bottom of a Murus wall panel is no different than what is standard in the SIP industry. The image in the Murus installation manual that you are referrring to is for wall panels installed on top of a concrete foundation, which will always need a PT sill plate. The width of the sill plate is not important as long as it is at least as wide as the panel itself. If the panels are being installed onto the floor deck (as in fig. 4A at the top of the page), no sill plate is required, only an inlet.
The next part of the installation detail shown on page 16 is for an "inlet" fastened to the sill plate. The inlet will be standard dimensional lumber, i.e. a 2x4 for a 4 1/2" panel and a 2x6 for a 6 1/2" panel. The exception is the inlet for a Murus 5 1/2" R-33 panel, which calls for a ripped down 2x6.
Note: Murus does not supply the 2x lumber.
Jay Shultz
The Murus Company
Jay,
Question for you. Why doesn't your company supply the 2x lumber? The company I purchased my SIPs from didn't either and I thought that strange. Only because I figured for a mark-up the SIPs company could make some "easy" money while at the same time provide that service to the customer. Not a loaded question as I am sure there is some logic. Just curious.
