Posted By LarryinIowa on 10/09/2009 2:10 PM
I am new to this forum. I am looking at using SIP's as a construction method for a new house. In talking with a dealer at a local home-building show; his statement about fiberglass was that it was a good filtering agent for air. However, it does help remove humidity in the air.
If houses are sealed so well is there a potential of having condensation on either the inside or outside of SIP walls? If it does occur, does it occur more with PUR or EPS? Is there a good countermeasure?
If this subject has already been beat to death, I'm sorry. As I said, I'm new to the forum.
Larry,
we are used to beating things to death , welcome to the forum!
a filter lets air flow thru which is not what you want for energy efficiency.
PU or EPS makes no difference as far as tightness, the best bet is to build as tight as possible and control the point of freshair intake. You need to contol high humidity to avoid condensation that will form on your windows first.
The countermeasure will depend on your climate, the cure will vary for different parts of the country
