jvwitt
| 09 May 2008 12:50 PM |
need expienced sip builder in boone nc |
cmkavala
| 09 May 2008 12:54 PM |
we travel............ but only to do steel SIPs |
Alton
| 09 May 2008 04:13 PM |
Are your steel SIPS polystyrene or polyurethane? |
cmkavala
jvwitt
| 10 May 2008 10:12 AM |
thanks alton---i intend to use urethane sip--walls, roof, and possibly floor--thanks again |
seaglade
| 10 May 2008 12:16 PM |
I used steel polyurethane SIP panels called ACTech Panel to build my small coastal cottage and I am very pleased. Check out Alternative Construction Technologies website. They have a plant in Tennessee, but ship everywhere. In Florida our building code standards are high, these panels have a Florida Building Code Number. |
GeorgiaTom
| 10 May 2008 01:08 PM |
Posted By seaglade on 05/10/2008 12:16 PM I used steel polyurethane SIP panels called ACTech Panel to build I have seen their panels they are only 3" thick x 24" wide (walls and roof?)and need stitch screws inside and out that other panel systems do not need |
GeorgiaTom
| 10 May 2008 01:16 PM |
You may want to consider the possibility of health hazards associated with PU
this exerpt from the pu.org website.............. "Engineering controls and sound workplace practices are often the first line of defense against diisocyanate exposures, and guidelines have been established to help individuals avoid overexposure and adverse health effects. Nevertheless, it is important that employees wear any personal protective equipment (PPE) recommended for their specific job functions. With proper precaution and the use of engineering controls and PPE, a worker can protect himself or herself from overexposure to diisocyanates.
It is important for workers to understand and adhere to safe handling practices for any chemical that poses a health hazard. This may include, but is not limited to, wearing eye protection, gloves, coveralls or lab aprons and respiratory protection.
To help protect workers from respiratory hazards and facilitate a company’s compliance with OSHA's Respiratory Protection Program Standard (29 CFR §1910.134), CPI developed a Model Respiratory Protection Program. The program, divided into ten steps, provides user-friendly documents for facilities and guidance on appropriate respirators, respirator use, storage, fit and evaluation.
Through these product stewardship services, CPI can help its members and their customers manage product development, manufacture and distribution, marketing, use and ultimate disposal of polyurethane products in a safe, healthy and environmentally sound way" |
GeorgiaTom
| 10 May 2008 01:24 PM |
Have not heard good things about PU - worth checking out:
OSHA
AFL-CIO
bpickartz
| 10 May 2008 02:25 PM |
Both of these sites refer to using polyurethane in manufacturing (the process where the chemicals are liquid). I've seen no studies that show urethane to be toxic in it's final form. |
GeorgiaTom
| 10 May 2008 02:32 PM |
bpickartz;
true, but they are also known to offgas for several months after mfg., to be an irritant to the skin,eyes, nose and throat while cutting on jobsite and
they shrink with age, loose R-value with age and for some reason attract insects |
Brawler
| 10 May 2008 07:21 PM |
Hi, I am building a superiorwall /sip house on Lake Norman and have chosen Robert Costanza with MMI construction In Nashville. Really nice guy who was recomended by Insulspan.
[email protected] |
cmkavala
| 11 May 2008 08:30 AM |
Brawler;
He sounds like a nice guy, because nice guys use EPS.
I am familiar with Lake Norman as it has a lot of house boats more like floating houses. We have been working on plans to build the floating houses and condos with steel SIPs for some owner/investors. They have had problems with wood construction prematurely rotting out due to the constant exposure to moisture over water(currently only having about a 7 year life expectancy) We are proposing aluminum or steel skin SIPs for: lighter weight, greater strength, resistance to moisture problems, speed of construction, fire resistance and economy with leaving the bare panel roof skin as the finished roof. These measures to lighten the entire building allows the use of smaller floatation which in turn results in additional savings. |
olpjeb
| 12 May 2008 11:15 PM |
GeorgiaTom -
With all due respect, you have no idea what you are talking about with respect to PU. The references you quote have to do with the individual components used to make PU. Yes, isocyanates by themselves are not good, but when combined with polyols, it makes an inert thermoset plastic foam. Your logic is equivalent to saying that salt (sodium chloride) is bad because it contains sodium (a highly flammable, dangerous metal in its pure form) and chlorine (a highly toxic gas in its pure form). Please, go back to your local community college and take general chemistry 101 and organic chemistry.
To others on this group - I apologize in advance for the tough worded note, but comments like the above, with no scientific merit, do nothing but spread fear. |
GeorgiaTom
| 13 May 2008 08:40 AM |
Olpjeb;
With all due respect to you as well, my logic is usually of common sense, I do not need to know anything about science to know that a hot stove will burn me. In the same token when I have cut and handled PU panels; the fine dust itches my skin, is an irritant to my eyes , nose and throat. Now you may think I'm just a dumb hick, but I state those facts from my own personal hands on experience. I don't care to have that dust circulating in the same air that I live and breath.
You also cannot deny that the PU is known to:
off-gas after manufacturing shrink with age loose R value with age has been known to attract insects
The report link is regarding PU dust in the home after MFG http://healthychild.org/resources/chemical-pop/polybrominated_diphenyl_ethers/
If you think those statements are false please respond to them individually.
You do not need college to make informed intelligent decisions
olpjeb
| 13 May 2008 02:08 PM |
GeorgiaTom -
Please read the article on PBDE's carefully. These are flame retardants added to various household components. They are NOT added to polyurethane foam panels because there is no reason to have a flame retardant panel. Talk to any PU SIP manufacturer and ask them if they use PBDE's when they make the PU foam. You will find the answer is NO.
As to the other claims on PU. Well, the same happens with fiberglass, cellulose and EPS. I will take PU or EPS foam any day over fiberglass (though I prefer PU). An inorganic substrate like fiberglass or asbestos, when inhaled, will have much longer-term adverse health effects than an organic substance that the body can at least break down.
And yes, you may have a sensitiviy to PU. That happens...It's called an increase histamine or allergic response. The same way I can eat peanuts all day long, but my son will go into anaphylactic shock from eating just one peanut. It all varies by the individual.
So - what is your idea of a perfectly GREEN insulation material...straw bale, cotton, recycled jeans, polyester fibers, an igloo? |
GeorgiaTom
| 13 May 2008 05:41 PM |
Posted By olpjeb on 05/13/2008 2:08 PM GeorgiaTom -
Opjeb; second line on report says "and insulation used around wires and in the home" I have no allergy to PU nor did the other 6 workers onthe job all were affected by the dust. It is simply an irritant. The following is taken from "the Green guide"
Polyurethane is actually another name for the family of chemicals known as the urethane polymers, which are composed of two principal raw materials, isocyanates and polyols, brought together with catalysts and a large variety of additives. Isocyanates are highly reactive; the two most commonly used in polyurethane production are toluene diisocyanate, (TDI) made from chlorine, toluene, phosgene, sulfuric acid, and nitric acid, all hazardous volatile organic compounds (VOCs), and methylene diphenyl diisocyanate (MDI), made from formaldehyde, sulfuric acid, nitric acid, phosegene, and benzene. In terms of environmental impacts, to make one kilogram (kg) of polyurethane rigid foam it takes an estimated 361 kg water, .98 kg natural gas, .69 kg crude oil, .41 kg coal, 19618 mg methane (CH4), according to the Association of Plastics Manufacturers in Europe. Meanwhile, production of this kilogram of rigid foam emits wastes including 3.7 kg of carbon dioxide, a major global warming gases, .5 kg chlorine ion and .29 kg sodium ion into water, .35 kg solid mineral waste. The numbers are similar for flexible foam. In terms of potential health effects, the neurotoxin toluene can offgas from the mattresses and other products . Phil Landrigan and Herbert Needleman note in Raising Healthy Children in a Toxic World (Rodale, 2001), that, when inhaled, the TDI in floor finishes "can cause airways sensitivity, and reexposure to TDI can cause chemically induced asthma."
The other principle polyurethane raw material, polyols, are compounds containing multiple hydroxyl groups (O-H groups). Frequently used polyols include various polyester and polyether glycols. As for additives, ozone-depleting chlorofluorocarbons (CFCs) were formerly used to produce softer, lower density foams; the industry moved towards methylene chloride, but the EPA is also limiting its use since chronic exposure may damage the nervous system and it is considered a probable human carcinogen.
I don't think any insulation is perfectly GREEN ........... the recycled jeans are pretty, but some how a material that has been on someones's behind for several yeasrs shouldn't be in my house.
I like EPS, for my coffee cup too! |
teslastones
| 13 May 2008 06:47 PM |
Not that I am stupid enough as to jump into the middle of a dog fight. I am genuinely curious what you guys would think of a foamed Magnesium Chloride cement. This is higher "R" value than fiberglass but does not settle, off-gass- degrade when wet, make a good home for bugs and other vermin, etc. etc. Does the word "Chloride" scare people away. I have developed this spray foam to the point where it is ready to go into the market but I am curious as to what people like yourselves would think of it. Ceramic Cement Research Institute |
GeorgiaTom
| 13 May 2008 06:55 PM |
teslastones;
sounds like salt of the earth |
teslastones
| 13 May 2008 07:23 PM |
Mostly derived from Sea water. When it is properly reacted with Magnesium Oxide and other proprietary additives (all mineral based) it results in first magnesium chlorcarbonate and then ultimately into hydromagnesite 5MGO-4CO2-5H2O which is insoluble and stable. Does your comment mean you would have a negative reaction even though all constituents of the process are things we ingest daily--in fact they are needed for good health. |
