Amvic Banner
User Name: Password:
Road BlockUser is Offline
05/27/2008 10:42 AM
Does anybody make a kitchen hood that also acts as a ERV or heat exchanger for a residential kitchen?
07/26/2008 2:59 PM
Think you might have a grease problem?
I have installed electric cook tops with no hood at all if there are no combustibles near,
You could then have a remote ERV exhaust near the cooking area
chris@southernsips dot com
ronaldsauveUser is Offline
09/02/2008 11:27 PM
I agree that you will have a grease problem with the ERV or HRV if used as a range hood.  However, I routinely locate an exhaust for HRV's in the kitchen.  Depending on the situation, I will use a recirculating range hood.
But you should not use an ERV or HRV for the range hood itself.
Ronald Sauve
www.greendesignbuild.net
