As a follow up question to my first question...
Since I will be installing radiant in the basement slab, should I follow through and put radiant in the entire house? It is a simple ranch with a walk out basment, ICF from the footers to the rafters. The first floor will be wood I-joists with wood floors throughout the house except the wet areas will be tiled. I am planning to heat the main floor with forced air, but I keep leaning back to the radiant since I will have it in the basment.
My location is rural Kansas City, the house will be all electric and wood will contribute sunstantially to the heat in the living/dining/kitchen area. My reluctance with radiant on the main floor is the use of a wood subfloor and the associated loss in effeciency.
If I go with just basement radiant, I plan to use a 40 gallon electric water heater as my heat source. If I go with radiant through out the house, will two 40 gallon tanks suffice? I have already decided against an open system, dhw will be provided through a tankless unit, brand yet to be determined.
Lots of questions, all answers and input welcome.
Dug
