News/Blogs
Free Quotes
Directory
Products
Leads
Green or Not
Services/Advertising
User Name:
Password:
Radiant Heating
> Subject: floor tubing runs
Prev
Next
Author
Messages
Oldest First
Newest First
gord
11/21/2008 3:26 PM
i am slowly adding infloor tubing under ceramic tile / plywood / 1" umplained boarding floor. My designer recomended double 1/2 " PEX runs between the joists with the appropriate radiant barrier and convection bat insulation under the radiant barrier.
my question is the method of attaching the tube to the underside of the floor. some designs recomend right against the floor, one said just against the joist near the floor.....i plan to base load the floor and use my pelet stove for the very clod weather. having said that the "plates" which from what i see only increase the feat transfer rate will not help.
what is the best method to secure the PEX and where. the gap i was told between the floor and the radiant barrier should be no more that enough so the barrier does not touch the PEX
thanks
Green or Not
--<a href="/buildcentral/gnot.asp">Green or Not</a>
Radiant Heating
> floor tubing runs
Copyright 2009 by BuildCentral, Inc.
Terms Of Use
Privacy Statement
