Posted By arcamm on 01/01/2009 11:56 AM
The building will be a metal/wood shop. It will be heated by a radiant system in the slab. Winter heating requirements would only be up to 60 deg F.
2" is probably OK for a shop, I question the neccesity for a HRV, an exhaust fan is probably better suited for fume and dust, your air infiltration will be around door and window openings, unless you provide another fresh air supply inlet near exhaust.
If you are already having trusses, purlins and girts like a traditional pole building you may want to consider 2"-3"steel SIPs that already have the roofing and siding integral with panels. saving a step and providing a clean washable interior surface
