Quad-Lock Banner
User Name: Password:
AUSTENNNUser is Offline
02/04/2009 8:17 AM
Where can I find a chart to see how much I can cantilever a SIP?  My interest is in a 8  inch roof Sip panel.
02/04/2009 8:21 AM
Posted By AUSTENNN on 02/04/2009 8:17 AM
Probably not going to find one,  6" and 8" steel SIPs can be cantilevered up to 4 feet
chris@southernsips dot com
jmagillUser is Offline
02/04/2009 8:32 AM
You can cantilever OSB sips.
You will need to deal directly with the SIP company to get the right answer. It will depnd on the engineering and how the SIP is constructed.
There is no one size fits all answer.
JBSUser is Offline
02/05/2009 8:03 AM
The first question I always ask is, "how much of an overhang would you like?"
The max overhang will be determined by the answers to the following questions:
1.) Snow loads & Wind loads.
2.) Roof pitch.
3.) Roof framing and direction of the panels.
4.) Using 4' wide or 8' wide panels.
5.) Does the eve detail have a soffit?
With these questions in mind give you SIP company a call.
Jay Shultz
The Murus Company
800-626-8787
Matt PhelpsUser is Offline
02/05/2009 8:37 AM
Do NOT guess!  Most SIP manufactures have span tables that will give you this information based upon the roof load(s) (don't forget to calculate the wind load)!
R-Control has an excellent span table and lots of designers use them.  They will contain all the information you seek.
If you have other ques tons feel free to contact me off line.
Good Luck,
Matt B. Phelps, P.E., R.S.
TDI certified windstorm engineer and inspector
02/05/2009 8:41 AM
Matt;
wind uplift is the predominent design factor in the Southeast  US coastal areas
02/05/2009 8:52 AM
Thanks I have the R-C book and will revisit it.
