It doesn't seem anyone wants to comment on this so i'll keep posting as i learn more. I really woudl like to put a small condensing oil fed boiler in but it seems these are going to be quite expensive. The four units i have come across are Viessmann Vitoplus 300 (i think only availble in UK); Buderus GB125BE; Monitor FCX; and Peerless Pinnacle. It seems just the boiler and trim kits put all of these at around $4-5k.
I'm second guessing myself hear and thinking maybe a small oil fed water heater, like the Bock 20e Space Savr, in a closed loop is a good option. Its relatively small, inexpensive, decent efficiency, and low enough BTU's for my space. My utlilty room is kind of tight with a full furnace and an electric hot water heater in there already. So if i can't afford a smaller condensing boiler, and a full size boiler may just be too tight, this seems like possibly a good option?? Although i'll do some solar thermal for my DHW eventually i sure wouldn't mind getting rid of that electric sink of a hot water heater. But i think most of you frown upon an Open hot water heater system for DHW and radiant, and from what i read for good reason. So i'll probably stay away from that.
Efficiency is very important to me, but i am on a budget, and seeing i already have a furnace and expensive electrc hot water heater i need to find a happy medium between efficiency, space savings, and budget. Any suggestions?? |
