Probably a simple question for this crowd.
First the setup: approximately 900 sq ft of a 1000 sq ft basement heated with a navien 240a and Heating box (and forced air). This unit is not modulated but i set it myself and currently with the milder climate (below freezing at night, above freezing during the day) the water going into the slab is about 38C. The thermostat is a Tekmar 508 with floor sensor set to floor sensor only. We have the t-stat set at 19C. The sensor is in the middle of the entire slab but on the edge of a radiant heated area next to an unheated utility room. The sensor is about 3" below the surface of the tiled floor in a drilled hole (ie easily retractable). Slab is about 5 ft below grade and about 6-8" thick.
Not an ideal setup but this is what we have to work with.
Problem. We set the t-stat and the radiant system warms the floor. Feels great as the equipment works to satisfy the t-stat. One the t-stat is satisfied, the unit shuts down and it doesn't run again for a day or two. Meanwhile after a half day of not running, the floor surface is not feeling like it is warm anymore but the t-stat is showing that it is still at 19C.
Questions. Is the floor sensor too deep? Is there that much of a temp gradient between the middle and top regions of a cement slab? Could i correct this problem by drilling a hole closer to the surface, ie just under the tile, and inserting the floor sensor there? I have access to the cement floor profile in this location so this is doable.
Any suggestions? If this is not enough info or not clear, please let me know
Thanks.
