Fibertec Banner
 News & Articles Minimize
Bolton Residents Utilized Alternative Energy Solutions
Posted By: Jamie  on 10/07/2008
“Heat pumps will save 30 percent on your oil bill annually yet systems are like cars and range from a VW to a Rolls Royce system which in this context could cost $3,000 to $18,000.”...
When it comes to alternative energy solutions several Bolton residents have taken the plunge and are utilizing the earth’s natural, fossil-free resources — earth, air, and sun.
For the past 25 years, Jane Moosbrucker of Coventry Woods Road has been taking advantage of the sun and air to heat and cool her home as well as to heat water. Moosbrucker opted for a Trane High Efficiency Weathertron heat pump from Chaves in Hudson. She uses electric heat and a wood stove as a backup for the three coldest months. In addition to helping the environment, Moosbrucker saves money on her electric bill over the course of the year.
According to Joe Chaves from Chaves Heating & Air Conditioning, Inc., “Heat pumps will save 30 percent on your oil bill annually yet systems are like cars and range from a VW to a Rolls Royce system which in this context could cost $3,000 to $18,000.”
Moosbrucker also has a solar hot water system with two solar collectors on the roof, and a 40-gallon water tank in the basement.
“I have always liked the fact that I don’t burn oil,” said Moosbrucker, but cautions those considering this solution that the system must be maintained. Since the heat pump is located on the outside of the house and pulls in heat from air, the vents must be kept clear.
In winter, after a snow or ice storm, the first thing Moosbrucker does is shovel off or de-ice the system and make sure it has plenty of clearance to be able to draw in air.
“For the young and energetic, it’s a great option as the house is very comfortable and we’re not burning oil,” noted Moosbrucker.
And newer systems include air purification which helps with allergies and asthma.
The Lama family on Quaker Lane chose a dual loop geothermal heat pump system by Alluvium Geothermal Systems. The system was installed a year ago. Geothermal systems essentially take advantage of the earth’s constant temperature by using the stored energy from the earth to heat or cool a home. By drilling an adequate well, water is heated in the winter by the warmer earth and cooled in the summer by the lower earth temperatures. This process creates heat and/or central air for your home as needed.
According to Chinloo Lama, her system “utilizes a loop of refrigerant in the unit that exchanges heat between the air and a second loop of water solution that ultimately loops through the ground for the geo-heat exchange.”
For those considering installing this type of system, Lama advises “do your research to make sure you know what type of system you want and ensure that your contractor is licensed, certified and accredited as a geothermal installer.”
Given there are several types of geothermal system options available, you should consult the professionals and your budget to guide you toward the appropriate system. For example, open-loop systems draw water up a well, exchange energy from water and return water to the ground through another pipe. While these systems are less expensive than closed loop systems where the pipes are all connected in a “loop,” the open loop systems may have some zoning restrictions that prevent it as a viable option.
For example, since the Lama family’s property abuts wetlands, they required a closed loop, 500-foot vertical well (as opposed to a horizontal trench configuration), an HVAC system, dual zone, and an electric water heater. If they did not want to use the cooling option of the geothermal system they could have had all of their hot water generated from the system as well.
Anyone considering new construction or an addition to their home should consider using geothermal heating systems as a viable option with radiant heat in the floors. These systems have been described as a “marriage made in heaven” in terms of comfortable temperature and efficiency. However, to retrofit an existing average size home, geothermal systems cost anywhere from $20,000 to $50,000.
For a photovoltaic solution that uses the sun’s energy to provide electricity, Bob Zak took advantage of a south facing roof in 2001 and installed “solar shingles.” This system blends right in with the house aesthetics and generates 6,900 kilowatts of electricity per year. The system was installed by Atlantis Energy using Sunslate technology. The cost ranges from $20,000 to $70,000 depending on the system size.
“I’m very happy with our system,” Zak said, “but there are many steps a family can take to save money and energy such as increasing insulation, using more energy-efficient appliances, and using things that require less energy.”
The Zak’s system provides about 50 percent of their electricity needs annually.
According to the Solar Works Web site, using this system will reduce 160,000 pounds of carbon dioxide a year or the equivalent of planting 749 trees.
On behalf of the Bolton Energy Committee’s community education program, John Balco has arranged an Alternative Energy Homes “Open House” on Saturday, Oct. 4, from noon to 4 p.m. The following homes will be open: Moosbrucker, 72 Coventry Wood Road; Lama, 67 Quaker Lane; Kischitz, 113 Berlin Road; Zak, 133 Wilder Road.
More options
Other alternative energy options to consider that have a shorter payback time include solar hot water systems and solar hot air systems.
The Kischitz family recently installed both systems in their house on Berlin Road. The three-collector hot water system includes a 120-gallon superstore tank in the basement which enables them to store the water for days at hot temperatures. On a sunny day, the water is coming into the storage tank heated at over 140 degrees. Thanks to the “super”-insulated tank, the water temperature remains hot, losing only about a degree per day and on average is about 120 degrees.
Having a solar hot water system allows you to shut off the oil burner “backup” in May and turn it on again in late September. The payback on these systems is between 4 to 6 years as the systems cost approximately $10,000.
Continue this article at The Bolton Common
Photo: Bob Zak's home on Wilder Road is topped with solar roof shingles.
View News/Articles List
