San Rafael architect Nabih Tahan designed his passive house in Berkeley (Provided by BAU Technologies)
November 8, 2009, by Jim Welte
Published by
Marin Independent Journal
WITH WINTER on the way, the idea of living in a home without a conventional heating system probably sounds like a recipe for disaster.
But a growing contingent of architects and builders, including several in Marin, are hoping to change minds throughout the U.S. with the concept of "passive house" design, which is founded on the idea that conventional heating and cooling systems are unnecessary, wasteful and damaging to the environment.
"We should be able to do this - I mean, we've been to the moon!" said Nabih Tahan, a 56-year-old San Rafael architect who is widely considered the pioneer of passive house principles in California. "It's incumbent upon us as architects and engineers to prove that it's possible."
For the past few years, Tahan has been giving lectures and workshops to architects and builders throughout California, spreading the passive house gospel. In doing so, he's used his home in Berkeley, which features airtight construction and an innovative ventilation system, as a model. The message spread to Fairfax architect Graham Irwin, who designed a just-completed house retrofit in Point Reyes Station that comes close to meeting the stringent passive house standards.
Those standards require creation of a home that is airtight with complex doors and windows and heavily insulated, so that barely any heat escapes and barely any cold air enters. The airtight frame lets the house be warmed not only by the sun, but also by the heat from appliances and even from occupants' bodies.
The home is anchored by a ventilation system that keeps fresh air moving throughout the house but also retains the heat or coolness of that air depending upon the season. The system's air-to-air heat exchanger sends the warm air going out right by the cold air coming in, exchanging heat with 90 percent efficiency. All of the heat given off by appliances, computers - even human beings - is captured and retained. Tahan said the ventilation system separates it from previous failed efforts in the U.S. to build passive homes, which suffered from mold and stagnant air.
The modern kitchen of a passive house in Berkeley. (Provided by BAU Technologies)
"It's like putting a plastic bag over your head - ventilation is the key," Tahan said. "The system used to make that happen is not standard in the U.S. We have heating systems, not ventilation systems. But if you add all of those things that give off heat together, that's a lot of heat."
To become a certified passive house, a structure must undergo an extensive test outlined by the Passivehaus Institute in Germany. The test measures air leakage from the building, and also uses a formula of kilowatt hours per square foot per year to measure its energy use. The structure must not exceed 1.4 kilowatt hours per square foot per year. The formula produces a building equivalent to the miles per gallon measure for cars' fuel efficiency, Tahan said.
A ventilator moves air from inside and outside the home to provide heating and cooling. (Provided by BAU Technologies)
Passive house standards go well beyond LEED, or Leadership in Energy and Environmental Design, the system developed by the U.S. Green Building Council to serve as a guideline for environmentally sustainable construction. Tahan said that system's emphasis on alternative energy sources like solar panels doesn't address the root problem: houses that leak air and require new hot or cool air to be pumped into the house to regulate the temperature. Tahan used the analogy of fixing a leaky gas tank by ignoring the leak and filling up with biofuel instead of gasoline. The change might make you feel like you're making a difference, but your gas tank is still leaking, he said.
"LEED is just prescriptive," Tahan said. "From an energy standpoint, it's not enough. It's certainly a step in the right direction, but we can't rely on technology like solar panels and not do the hard work. We have to focus on the core problem, which is the house itself."
Tahan concedes that passive house design has a long way to go in the United States. While there are fewer than 15 passive structures in this country, according to the Passive House Institute in Urbana, Ill., that figure is expected to crest to 100 by 2010. But those numbers pale in comparison to the more than 15,000 passive houses that have been built in Europe in the two decades since the system first gained prominence.
The primary obstacle is lack of awareness, Tahan said. To combat that, he's been evangelizing about its principles, but said he knows that the best way to educate people is by showing them. His home in Berkeley has done just that, as has the Point Reyes Station project that was co-designed by Irwin.
The latter property is owned by the Community Land Trust Association of West Marin, or CLAM, which was founded in 2001 by community members to create stable and affordable housing in West Marin.
The retrofitted, two-bedroom home, completed in late October, dates to about 1920. The retrofit drastically reduced its emissions to close to zero, a process association officials characterized as turning a "Hummer into a Prius." The association plans to turn the second home, which is a building from scratch, into a net zero-energy home, and although the project has yet to go out to bid, the group hopes it will be the first certified passive house in California.
Point Reyes contractor Terry Nordbye was the builder on the project, and learned about passive house construction from Irwin.
"I've been a builder for 30 years, and I'm a convert," he said. "It's like no house I've ever been in. They are incredibly evenly tempered, with minimal fluctuations."
Continue at Marin Independent Journal
