Insulating Slab?
Last Post 21 Aug 2007 12:19 PM by NRT.Rob. 1 Replies.
Columbia34User is Offline
21 Aug 2007 12:16 PM
I am in the planning/getting building permit stage of building a 30x40x14 pole barn. Were are located in Battle Creek , Mi ( SW Michigan ). I am going to do a radiant slab, with a water heater. The building will be 1200 sf. My question is how big of a water heater? our fuel source is propane. Next is insulation, walls and cieling will be fiberglass bats walls R21 and cieling R38. The floor will just be a slab on grade what do you suggest, the floor is not within 3' of gorund water. I was thinking sand base, vapor barrier, 2" dow board, 4" concrete. Also though about digging a 2' deep trench along the outside and putting a 2" dow board on edge around the whole exterior. I am doing over kill and can I cut cost on the insulation i would like to heat all winter long say around 55. Thanks. call if you want to chat. thanks for your help.
Scott
You've got it just right, though in your climate a water heater might not be your best bet here. Perhaps... depends on the overall heat load. At 55, it's probably fine, but if you decide you want it warmer a higher efficiency heat source would *probably* meet your needs better.
Insulation is the gift that just keeps on giving; don't skimp there.
People Online People Online: Visitors Visitors: 545 Members Members: 0 Total Total: 545
