Posted By Guardrail Driver on 09/21/2007 2:33 PM
Thanks Rob, I am still in the planning stage. As I get closer I will probably ask some more questions.
Enthusiasm among HVAC traditionalists is still low for this, and many are just plain naysayers, but since you're in the planning phase explore the idea of ceiling radiant and using it for cooling also. Humidity control is accomplished by ventilation and dehumidifying the incoming air. If you're planning on using forced air for a/c you can reduce the size of your air handling system significantly. For starters check out these sites. http://www.bekausa.com & http://doas-radiant.psu.edu/doas.html.
