boiler and/or water heater
Last Post 17 Nov 2007 10:15 AM by embie. 2 Replies.
embieUser is Offline
15 Nov 2007 01:38 PM
I am planning a home heated with hydronic radiant flooring.  I have never before specified one and cannot discern from my research if it is desirable to have a boiler to supply the system and then a seperate water heater for other hot water needs.
I believe I read somewhere that using a vanilla water heater to supply the hydronic will wear out the heater.
Can a boiler also be used to supply the other hot water needs?
Thanks!
15 Nov 2007 05:57 PM
Posted By embie on 11/15/2007 1:38 PM
Last sentence: Bingo! Get a modulating/condensing boiler and a 'sidearm'(indirect WH). The 'sidearm' acts as another zone, usually has priority, and will provide all of your DHW needs. You can size your tank to your needs(40, 60, 80 gallons)
I would avoid a standard WH for efficiency reasons, it's ability to 'recover', and you certainly don't want an 'open' system.
THANK YOU!!!
People Online People Online: Visitors Visitors: 592 Members Members: 0 Total Total: 592
