Radiant Heating
Would radiant heat be enough?
Last Post 31 Dec 2007 01:50 PM by
David hot
. 2 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
TheSiege
06 Dec 2007 04:53 AM
Would radiant heat be enough heat in a basement made intirely of nudura ICF? in utah, and about 1800 sq feet? and if so how do most people cool thier basement if they arent using a forced air system and just radiant heat?
gregj
06 Dec 2007 04:12 PM
Sure, if designed properly.
Around here, A/C is typically accomplished with a central forced air a/c system regardless of type of heat.
David hot
Look into the split A/C sysytems with the compressor outside & an air handler on the wall . The ICF wall will stabilize temperatures so heat from windows is the major effect to watch for in sizing A/C
Radiant Heating
Membership:
croccohvacusa
People Online:
