Spray Foam Insulation over Staple Up
Last Post 01 Jan 2008 06:32 PM by drchcllc. 2 Replies.
drchcllcUser is Offline
31 Dec 2007 08:50 PM
Can't find any sources to comment on the benefits, if any, of closed-cell poly (bio based) insulation sprayed directly on stapled-up PEX after it has been set in aluminum tracks between floor joists.  However, I have read about the necessity of keeping an air space between the PEX and more traditional insulation methods.  Question is, is it or is it not advisable to use spray foam insulation in such an application.  Thanks in advance...Cant imagine why it wouldn't be the cat's meow but you never know.
01 Jan 2008 11:26 AM
it's good, but I would advise a "shield" of cardboard, just to make sure the spray foam doesn't get between your aluminum plate and the subfloor. Foam can work itself into small cracks and that would reduce the plates' effectiveness.
Thanks Rob...appreciate this and any advice you might provide in the future.
People Online People Online: Visitors Visitors: 547 Members Members: 0 Total Total: 547
