Radiant heat vs heat pump in coastal carolina
Last Post 14 Jan 2008 02:37 PM by gregj. 5 Replies.
markp46User is Offline
07 Jan 2008 03:39 PM
Will be building an ICF house coastal North Carolina.  Two story on raised concrete platform.  Trying to determine the benefits of radiant heat in that climate in an ICF house vs standard heat pump.  Also need advice on cost considerations as well as modifications to air conditioniing system that should be considered.
10 Jan 2008 01:10 AM
What's the winter temperature swings like there? I lived in Hammond, LA for 15 years. During the winter I worried about wearing out the thermostat switching it back and forth between heat and cool!! :-) At least it seemed like it. If NC coast is anything like that I would be skeptical about radiant working like you would want it too because you would want to go from heat to cool in fairly short order and fairly often. You need a system with fast response for that. Radiant, particularly if you put into concrete slab, is a slow response system. That's the only issue I can see at this point.
caja_caUser is Offline
12 Jan 2008 07:24 PM
I think you can do radiant heating with a heat pump . I guess it would be a desupper heater / water to water unit. Or have I misunderstood?
oops NM, concrete is poured allready
14 Jan 2008 01:14 PM
Currently live in upstate NY in stick built with forced air for heat. No living experience in NC.  Coastal NC appears to have 3 months in the 30's at night requiring heat with day temps in the 50's.  Not sure if that constitutes fluctuations in temp.  But was under the impression that ICF structure mediates temp fluctuations.  Is that correct?  Have pretty much decided to incorporate RH in building the ICF house in NC since AC is the most important and would rather be able to separate the systems to place vents near ceiling to maximize efficiency for air and during months requiring heat to be comfortable as well.  Is this logical?  So would a heat pump provided cooling as well as heating for the RH?  Or would a boiler or water heater be more appropriate for the heating supply for the RH and then a strict air conditioner for cooling.  Looking for advice.  Thanks
gregjUser is Offline
I like radiant heat but honestly a heat pump with forced air sounds perfect for your area. Wiith such small need for heating I can't imagine spending the $ for radiant when your heatpump should provide plenty of heat. I don't think the high location of your registers (optimized for A/C) would cause a problem when you need to heat in such a mild climate.
People Online People Online: Visitors Visitors: 535 Members Members: 0 Total Total: 535
