We want to put in radiant heating in part of our walkout basement and have a maximum of 1 1/2 inches to work with. The finish floor will be vinyl. I found a great article comparing panel products (http://www.chple.arch.vt.edu/CHPLE%20Research%20files/Khanna,%20Amit.pdf) and think I would like to go with the Roth product because it was rated high and it's made from foam insulation which I believe is a good idea for a slab installation. Has anyone had any experience installing this on a slab with an overlay of luan or 1/4 inch plywood and a vinyl floor? Any other product recommendations?
