Hydronic vs Low Voltage Radiant
Last Post 04 Jun 2008 10:51 AM by BadgerBoilerMN. 4 Replies.
tyr2005User is Offline
12 May 2008 08:38 PM
I am building a log home this summer and considering radaint floor heating. I have been considering a hydronic system, but resently came across low voltage systems. Low voltage looks good and easy to install .  The question that I need to know is how is the operational cost compared to hydronic using a propane boiler.
Does anyone have experience with low voltage system and wind power or Photovoltic?
warmsmeallupUser is Offline
13 May 2008 07:57 PM
Log homes are always a little tricky and a heat loss calculation is required before you will get any real information from the use of any radiant system. However, we have a few homes now with low voltage as primary heating. I can supply you information to what they are paying based on their design specs and you can go from there.  Once you supply what you pay per kilowatt hour to your utility as well as construction designs we can help in coming up with approximate costs.
You'll have to go to a hydronics installer for their running costs...
<a href="http://www.comfortradiant.com" target="_blank">COMFORT RADIANT HEATING, LLC</a><br> <a href="http://www.comfortradiant.com/zmeshinterior.php" target="_blank">Floor Warming</a><br><a href="http://www.comfortradiant.com/roof-deicing.php" target="_blank">Roof De-Icing</a><br><a href="http://www.comfortradiant.com/snow-melting.php" target="_blank">Snow Melting</a>
17 May 2008 12:01 PM
You don't need to look at other projects costs; that doesn't tell you one single thing about your particular house. Our industry is literally littered with "my last house cost blah" and "I am paying half of what my neighbors pay" and other such useless anecdotal info; it doesn't help at all.
Figure your heat load in BTUs per degree day, multiply by degree days for your area. that's BTUs/year. As warms noted, it's very tricky calculating this number for log homes and it's a necessary first step before you install ANY heating system if you want good results.
Electricity of any kind meets that load at 3412 BTUs/kwh. multiply by your kwh pricing.
Hydronics, it will depend. If you get a very high efficiency system (low temperature, modulating/condensing boiler) it could be up to 99% efficient but you are mostly likely to be in the low to mid 90's. for estimation, divide your load by your estimated efficiency (90% would be divide by 0.9). Divide the new, larger BTU count by 92,000 for the BTU content of a gallon of propane. now you are at gallons of propane, multiply by your propane cost.
and you have a ballpark estimate of yearly heating costs. All assuming the systems are installed well; and this is ballpark, wide ballpark anyway. on any home a heat load calculation is an educated marker but not a perfect prediction... more so on a log home.
as a nod to warms, I will note that the competence of your hydronic installation will affect the hydronic number a lot more than the electric system. so if you are working with an installer you are NOT confident in, you might run those numbers for a lower efficiency estimate and see where you are at.
BillNUser is Offline
24 May 2008 09:56 PM
In my area, northern NJ, electric is about 3 times the price of natural gas. If electric is only 20% more efficient the choice is obvious.
I understand the price of electric in other parts of the country is far less expensive then what I pay.
BadgerBoilerMNUser is Offline
Wind and solar are years away from being viable for heating. Price per therm electric vs. propane and use hydronics so you can change your mind when electric goes through the roof.
