Hydronic and electric radiant in the bathroom.
Last Post 04 Jun 2008 08:46 PM by RKO. 4 Replies.
Road BlockUser is Offline
19 May 2008 07:59 AM
We’re finalizing the plans for the house and now in to the details of construstion.   We will be using ground source for the primary HVAC and desuperheater for DHW.  The master bath is about 13x15, 200sf in a corner so it has two outside walls.  Does it make sense or create problems to install hydronic and electric in the bathroom?  We like the idea of warm floors in the bathroom year round and this is the most cost effective method I can come up with.  The rest of the suite will be heated by hydronic, the electric would be on a timer and only be used in the morning, hydronic would be used the rest of the time.
Any alternatives would be appreciated.
BrockUser is Offline
19 May 2008 03:23 PM
Not sure you would need it, but if it were me I would put it in. You might not use it much, but to go back and add it later would be a much larger task and cost a lot more.
warmsmeallupUser is Offline
19 May 2008 07:06 PM
What's the heat loss in that room? Don't think radiant as primary heat without it.
<a href="http://www.comfortradiant.com" target="_blank">COMFORT RADIANT HEATING, LLC</a><br> <a href="http://www.comfortradiant.com/zmeshinterior.php" target="_blank">Floor Warming</a><br><a href="http://www.comfortradiant.com/roof-deicing.php" target="_blank">Roof De-Icing</a><br><a href="http://www.comfortradiant.com/snow-melting.php" target="_blank">Snow Melting</a>
BillNUser is Offline
21 May 2008 08:54 AM
I have done some jobs (including my own) where I put hydronic radiant in the floor & ceiling. The floor shuts down in the summer, but I can still call for the ceiling radiant because its on a different loop.
RKOUser is Offline
Install it now, not later you will not regret it at all. Count on about $14 - $18/Sq/Ft. Installed.
People Online People Online: Visitors Visitors: 414 Members Members: 0 Total Total: 414
