Should I bury poly?
Last Post 30 Jun 2008 07:48 PM by Brock. 1 Replies.
eicmanUser is Offline
30 Jun 2008 12:07 AM
I'm about to pour a concrete floor in the basement of my 1930s farm house (900 sq ft)
Should I bury a massive amount of 1/2" poly and use the coolness of the earth to cool my house?
Or is this about the dunbest post you've ever read?
Eicman
BrockUser is Offline
I don't know what your ground temp is but I am guessing you would need about 10,000 feet of pipe buried below frost and spread out at least a foot between pipes to get cooling. Even then if you’re in a warmer climate it will probably warm up the ground and you will loose most of your cooling. It is better then nothing though.
People Online People Online: Visitors Visitors: 223 Members Members: 0 Total Total: 223
