Metal Studs conducting heat from flooring?
Last Post 22 Aug 2008 05:24 PM by warmsmeallup. 2 Replies.
hudelhausUser is Offline
22 Aug 2008 04:10 PM
Hi,
A quick question - what, if any, impact would there be in using metal studs with radiant floor heating? Won't the metal studs conduct the heat very quickly (vs. interior wood framing)?  Would that matter much?
22 Aug 2008 04:12 PM
that is a facinating question. if you were on a slab, it might make a difference. Otherwise I doubt you'd have a conductive path to the studs that would do much.
warmsmeallupUser is Offline
As Rob says, it will, but not enough to matter because they're usually interior walls, so it stays in the envelope. We install alot in NYC where there is nothing else used but metal studs. I've never seen metal used as the sole support for the exterior walls. Most are concrete, brick etc, with steel framed windows. In this case, the metal framing is used in the heat loss calc.
<a href="http://www.comfortradiant.com" target="_blank">COMFORT RADIANT HEATING, LLC</a><br> <a href="http://www.comfortradiant.com/zmeshinterior.php" target="_blank">Floor Warming</a><br><a href="http://www.comfortradiant.com/roof-deicing.php" target="_blank">Roof De-Icing</a><br><a href="http://www.comfortradiant.com/snow-melting.php" target="_blank">Snow Melting</a>
People Online People Online: Visitors Visitors: 159 Members Members: 0 Total Total: 159
