Circuit Breaker
Last Post 29 Aug 2008 08:32 AM by warmsmeallup. 2 Replies.
MaxParkUser is Offline
27 Aug 2008 06:24 PM
This forum has been very helpful with my DIY project so far. I have a bathroom that is going to be using 150 sq feet of danfoss lx cable. Do I need a GFI circuit breaker?
BigIrishInstallUser is Offline
28 Aug 2008 10:48 AM
Hello MaxPark - I have installed several Danfoss LX systems and they usually come with a thermostat that has the GFCI already built into it. Check with your dealer or the installation literature that was provided with your T-stat and I can bet you have a GFCI thermostat. Placing the same protection at your breaker will cause the breaker to "trip" and not function properly. If you have a GFCI protected T-stat, then a standard breaker in your panel is all you will need! Good luck and enjoy.
warmsmeallupUser is Offline
Hey Max!
If you're using a Danfoss tstat, I agree with Big Irish.
But, this is just an off-handed question; are you using their 160sf cable kit and making it fit into your 150sf bath or a 145sf mat and leaving out the extra 5sf? We sell and install lots of Danfoss radiant heating and they don't have an LX cable or mat that specifically fits 150sf.
Just curious.
<a href="http://www.comfortradiant.com" target="_blank">COMFORT RADIANT HEATING, LLC</a><br> <a href="http://www.comfortradiant.com/zmeshinterior.php" target="_blank">Floor Warming</a><br><a href="http://www.comfortradiant.com/roof-deicing.php" target="_blank">Roof De-Icing</a><br><a href="http://www.comfortradiant.com/snow-melting.php" target="_blank">Snow Melting</a>
People Online People Online: Visitors Visitors: 347 Members Members: 0 Total Total: 347
