Posted By Boontucky-girl on 09/09/2008 2:06 PM
So then you are basically saying that I can buy the cheaper pipe and still be ok? The housepex is an oxygen barrier type A, 1/2 inch which is about $100 cheaper for a 1K ft. coil. than Zurn.
Non barrier should generally be cheaper than barrier. With non barrier you will need to use stainless steel or brass pumps, fittings, etc., because the oxygen that gets through the PEX won't affect those. With barrier you can use cast iron pumps and valves, etc., which are cheaper. You need to price out the entire system to figure out which way is best for you. Other than the barrier/non barrier aspect PEX is pretty much PEX regardless of brand. The local plumbing wholesaler I'm buying my plumbing stuff from gave me two or three different brands of PEX without regard to brand name.
With water supply plumbing barrier doesn't buy you anything because oxygen gets carried in with the continuous supply of fresh water. In the heating system if you keep new oxygen out you won't have a rust problem because the oxygen in the initial fill of water gets taken out by the metal in the system. If you're not adding water all the time the only oxygen that can get in is through the piping. Oxygen molecules travel through PEX, water molecules don't.
