Foil Barrier
Last Post 27 Sep 2008 11:40 AM by NRT.Rob. 1 Replies.
tyr2005User is Offline
27 Sep 2008 09:38 AM
We are building a log home and considering electric radiant heat under hardwood flooring, my problem is the reflective barrier, it would be hard in areas to staple a foil insulation to the underside of the subfloor because of the spacing of the engineered floor joist in areas. Can put foil insulation on top of the subfloor and install your electric radiant heating system over the foil?
http://www.flickr.com/photos/29703438@N03
reflective barriers are totally useless without an airspace.
you would need to insulate another way.
People Online People Online: Visitors Visitors: 178 Members Members: 0 Total Total: 178
