need an engeneers help for china charity work
Last Post 02 Oct 2008 08:35 AM by BadgerBoilerMN. 1 Replies.
[email protected]User is Offline
02 Oct 2008 08:27 AM
i just spent 3 months in china getting  local goverment permission to build sip homes for earth quake victims ,and got it! my foundation plan is to build 16x28 unit and join them together in an H pattern   with group bath rooms joining the two units. the local people traditionaly do not have heat or not much heat in there homes, my goal is the heat these unit to a point where they won't see there breath in winter inside the home. i'd like to install 1/2''
pipeing in the floors with a small locally available pump, and a 10 gallon water heat and use anti freeze in it rather than water so it does freeze when not in use.
my question are; 1 . how many feet of pipeing do i need to install
                            2.what size motor sould be used
                            3. how much heat will the 10 gallon water heat put out
                            4. how would you recomend i change this to make it feasible to take the cold out of home
the plans for the shelter  are on my web site; http://disaster-relief-shelters.org/china/
 thank you for your assitance please contact me thru web site
DISASTER RELIEF SHELTER FOUNDATION INC a florida non profit corp.
roland catellier
BadgerBoilerMNUser is Offline
I designed a similar system 10 years ago. Contact me directly with a drawing of your construction spec. and I will forward the details.
People Online People Online: Visitors Visitors: 178 Members Members: 0 Total Total: 178
