<!--[if gte mso 9]>
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
MicrosoftInternetExplorer4
/* Font Definitions */
@font-face
{font-family:"Cambria Math";
panose-1:0 0 0 0 0 0 0 0 0 0;
mso-font-charset:1;
mso-generic-font-family:roman;
mso-font-format:other;
mso-font-pitch:variable;
mso-font-signature:0 0 0 0 0 0;}
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-signature:1627400839 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-unhide:no;
mso-style-qformat:yes;
mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Tahoma","sans-serif";
mso-fareast-font-family:"Times New Roman";}
.MsoChpDefault
{mso-style-type:export-only;
mso-default-props:yes;
font-size:10.0pt;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
<!--[if gte mso 10]>
<!--[if gte mso 9]>
Normal
0
false
false
false
EN-US
X-NONE
X-NONE
@font-face
mso-font-charset:1;
@font-face
mso-font-charset:0;
margin:0in;
font-size:12.0pt;
.MsoChpDefault
font-size:10.0pt;
@page Section1
{size:8.5in 11.0in;
div.Section1
{page:Section1;}
Hello,
My contractor recently installed radiant floor heating system
retrofit in our basement. I installed a Tekmar 508 thermostat with a
floor sensor. I drilled a 2 inch deep hole in the concrete in the middle
of the basement below the thermostat just wide enough to accept the
sensor.
I wanted the floor sensor since the basement is also served by forced air heat,
and i would like to maintain a warm floor in the future.
The slab is 4.5 feet below grade.
I am still finishing the basement so we haven't had the basement as warm as we
will later on. Currently the minimum temp is set at 16.5C.
The cycling setting is on auto.
The
ambient temp sensor is turned off.
If i turn the minimum temp up to 17C, the zone turns on but it seems to turn
off again before the sensor temp hits 17C, and it seems to run in short
bursts.
The hot water is supplied by a
tankless hot water heater, so I don’t believe short cycling would be a problem
here.
My primary question is, what is the swing temp for a Tekmar
thermostat? I called them but it seemed
like it was a kid who didn’t know much on the other end.
