Is there any particular reason I cannot, or should not, use rosin paper as an underlayment for a floating, edge glued, engineered wood floor? I'm putting this over a crawl space I'm using as the heating/cooling system supply plenum. The intent is to have a semi-radiant heated floor so obviously I want the minimum possible thermal barrier under the flooring.
The best other choice I find is SCI (Sponge Cushion, Inc.) 1/8" rubber underlayment but it's a bit pricey. Rosin paper isn't listed in the flooring floating installation instructions.
