Radiant Ceiling Heat (Ceil Heat) Thermostats
Last Post 03 Feb 2009 06:25 PM by walltech. 6 Replies.
jmkjmkUser is Offline
01 Feb 2009 03:48 PM
I’m fixing up an older duplex.  One side has a heating system I have never seen before.  The thermostats say ceil heat.  A few weeks ago they were working fine.  Now, they won’t turn off.  We did remove the covers on the thermostats to paint but even after putting them back on the heat just keeps coming.  Any thoughts?  What’s involved in replacing the thermostats?  If I simply remove the thermostat in one of the rooms shouldn’t the heat turn off?  Are the thermostats 24v or line voltage?  Any ideas would be greatly appreciated.
warmsmeallupUser is Offline
02 Feb 2009 10:16 AM
Is the radiant system an electric radiant or hydronic (water in pipes) system? What's the model of the thermostat?
Can you post a picture of it if you don't have the model number?
<a href="http://www.comfortradiant.com" target="_blank">COMFORT RADIANT HEATING, LLC</a><br> <a href="http://www.comfortradiant.com/zmeshinterior.php" target="_blank">Floor Warming</a><br><a href="http://www.comfortradiant.com/roof-deicing.php" target="_blank">Roof De-Icing</a><br><a href="http://www.comfortradiant.com/snow-melting.php" target="_blank">Snow Melting</a>
02 Feb 2009 10:30 AM
CeilHeat Inc. is (was?) an early electric-radiant company "back in the day" ('60s? '70s?) and it's most likely an entirely line-voltage system. I dont' know if there was any sophistication built into the thermostats (PID & anticipating control algorithms controlling duty cycle etc seem like a much later sort of feature.) Any decent electrician should be able to pull the thermostats and give you an opinion, could be you just painted some mechanical aspect into the "contacts closed" position, but don't count on it. You may be able to swap in a sufficiently-rated line voltage thermostat for electric baseboards, or repair the beast in hand.
If you know which breakers/fuses run the system, pull the thermostat- it may have current & voltage specs on it. Anything you replace it with needs to meet or exceed those numbers.
02 Feb 2009 10:33 AM
It's a 220 electric. I had my son pull the thermostat and there is a red and black wire going to it. No picture right now but if it will help I can try to get one. The info that is legible on the thermostat is CHT-5 22amp 125/250 VAC. The control is a simple thumb wheel with the numbers 1-5 on it. On the 2 that aren't working one has a lot of rust and the other had something wedged inside the housing.
02 Feb 2009 10:36 AM
Thanks for the feedback.  The system probably went in during the 60s.  I did have the voltage checked and its 220.  I may try the local supply house to try and get a couple of repalcement thermostats.
02 Feb 2009 10:39 AM
Thanks to Dana's infinite knowledge of 'back-in-the-day' equipment, look to Aube Thermostats. They have many different types of line voltage controls (120 or 240v) you can update your controls to.
walltechUser is Offline
These should be easily replaced with a thermostat for radiant electric that has the same knob style configuration with the temp # on them.
Thanks Dave
People Online People Online: Visitors Visitors: 225 Members Members: 0 Total Total: 225
