Radiant install over uninsulated slab
Last Post 15 Feb 2009 10:17 AM by quailrunner. 3 Replies.
quailrunnerUser is Offline
08 Feb 2009 02:37 PM
I am considering a radiant installation for a cold (50 F) basement.  My less-than-precise heat calculation indicates that heat requirement will be 30-40 btu/ft on a zero-F degree day (about as cold as it will get in a typical winter here - southern NY).  I will get a more accurate heat calc from a company in a few weeks.  I've done one install (in another house) previously and it works fine (better now after I took the advice from folks on this forum and insulated the joist space under the loops - 25% decline in propane use over last winter, and this winter has been colder).
My issue is that the house, built in 1980, does has an uninsulated slab.  How is this typically addressed?  I have about 2.5" of build-up space available above the slab, so I could put down a layer of XPS and staple pex into that; is that a reasonable approach?   Is a plywood layer below the pex also (or instead) a good idea?  There are precious few contractors in this area who do this, and the two I called are not interested in this (740 sqr ft) job.  One made the comment (which I am seriously considering) that the cost will be very high for the sqr footage, and to go with another option (but offered electric, which I will not consider).  There was an electric baseboard heater in the basement when we moved in; our first Nov, the electric bill spiked almost $300, and I turned it off and ripped it out.  Elec is $0.15/KwHr here, so no electric option is going to be reasonable. The house has a forced air furnace (w. basement supply & return vents), but it typically does not run because I burn wood instead (house had both systems when we bought it); the wood is essentially free.  But, woodstove is on the first floor, so the basement never gets any heat.  My wife *loves* the radiant heat at the other house, and really wants to do it, expensive or not; we spend a lot of time in the basement as the entertainment center is located there.
BadgerBoilerMNUser is Offline
08 Feb 2009 05:01 PM
Vindicated again on electric heat...thank you.
Start with a proper heat load analysis (unless I misread your address and you are really in Fairbanks, Alaska, your heat loss est. is too high).
The answerz: insulate, staple tube to insulation and pour concrete or gypcrete on top. Combi1 from Bradford White for domestic hot water AND radiant floor heating all in one 82% gas-fired appliance.
Have it designed and specified by an RPA certified designer and let it out to your local plumber.
Don ReganUser is Offline
15 Feb 2009 09:01 AM
We have a 1" product that is perfect for this type on install called Crete-Heat.
Thanks! I'll look into that. I'm limited here by the contractors willing to use a particular product (I will not try to do this myself), but I'll see if any of the people who work with this kind of preparation will use that product.
People Online People Online: Visitors Visitors: 198 Members Members: 0 Total Total: 198
