If a house is left unoccupied in the winter, is it better to winterize (ie drain the system) or use antifreeze in a closed loop hydronic system?
Which is more convenient? (ie draining/refilling water vs charging with antifreeze mix)
Does any potential advantage of antifreeze offset the added inefficiency?
Details:
Small house in Maine (25K BTU Heat Load), Average minimum low 14 degrees, Hydronic closed loop system, Mod/Cons boiler such as Laars Mascot HT330 (also used for DHW). House isn't used Nov-March some years. Note that the DHW system would be drained regardless.
If I used antifreeze I would probably use 30-40% Propylene Glycol mix and set up the system to maintain in house temperatures above 15 degrees.
I know the Hydronic system is slightly off topic for this forum but I think the expertise here is better :-)
Tom
