Hi Henry, Shortly we will be pouring a monolithic concrete pad for a new building that will have Radiant Floor Heat. In fact we will be starting to laying the pex tubing today. We will have 6 loops and and two zones. Having done the layout of the pex per room and the supply and return runs pass through the door ways there should not be any chance of nailing into the pex tubing. The pex tubing runs are keep back from partition walls 6 inches on each side. If you are just in the planing stages and haven't started work yet, I'd be happy to send you some pictures. My email address is
[email protected]
