Pigmented Concrete and inlay over radiant
Last Post 27 Apr 2009 10:05 AM by sequim. 8 Replies.
sequimUser is Offline
24 Apr 2009 12:06 PM
So, I want to have concrete floors that are a combination of inlay and pigmented concrete (not dyed or acid etched), AND I want to use radiant heating in the floor.
Do I put down insulation, then pour the slab, 3-4" thick, then put in radiant tubes, then pour a 2" top of pigmented and inlay?
Or,
Do I put down insulation, put down tubing, then pour a 4" slab with the pigment throughout and add inlay on top?
Or,
Something else?
-a-
24 Apr 2009 01:07 PM
As long as the pigments are mineral I can't imagine the PEX tubing would be affected. A 2 or 3 step pour has inherent bonding issues that have to be attended to- methinks it safer/easier/cheaper to do it as a single pour if you can, but if you need a separate pour to be able to get the inlay right, limit it to 2 rather than a 3-layer bonded-slab.
24 Apr 2009 01:28 PM
What do I need to do to make the two layer bonded slab? Is it an adhesive, or is there a physical connection...
BadgerBoilerMNUser is Offline
24 Apr 2009 03:17 PM
In the vast majority of residential slab systems I spec. EPS, PEX and concrete atop. Your concrete applicator can speak to issues of floor finishes. Many now specialize in concrete flooring products.
24 Apr 2009 03:32 PM
Well, that's just it... i don't want just a finish, but a deeper product, like pigmentation and inlay.
24 Apr 2009 03:48 PM
We do it all the time. PEX stands up to nearly everything as Dana suggests, save petrochemicals.
24 Apr 2009 04:15 PM
So, then I wonder what would be more COST-effective?
1) Insulation, mesh net reinforcing and PEX tubes, under 4-5" White concrete, with mineral pigmentation, with inlay on top; all in ONE pour.
or,
2) insulation under standard concrete pour 3", PEX tubing, then a SECOND pour 1-2" of the white, pigmented concrete, bonded to the first.
26 Apr 2009 11:38 AM
I do not understand the inlay?
I agree the least $ and best way is a 4 in slab on insulation, color it ad you need pre-pour done.
I have had some clients come back and cut a 1/4 x 1/4 deep score on a 2x2 or 4x4 pattern, looks good, one fellow did this and then did terrazzo finish with brass slipped in to the score, looked good. cost $$.
what is the in lay?
Dan
Dan <br>BlueRidgeCompany.com
Inlay would be similar to terrazzo, I hope. I am looking at crushed agate-like stones, or similar. I've not seen brass added after the pour, so that would be interesting to see. I know Terrazzo does a pour over a sand cushion, with brass dividers at logical intervals. That is indeed expensive. I'm hoping to do something similar a bit cheaper.
