i live in british columbia canada, and i've built a 2400 square foot shop and i want to put radiant heat in the slab. i've heard of several different ways of doing this. 1 vapor barrier,2" foam insulation,and then wire mesh with the pex pipe tied to it , then concrete poured over top. 2, vapor barrier, 2" foam, pex pipe attached to the foam, covered in a layer of sand, with concrete over top of this. anyone have any pros and cons to these ideas? thanks |
