Strength of foam board insulation
Last Post 05 Jun 2009 09:14 AM by greeninsulation. 23 Replies.
04 Jun 2009 08:40 AM
definitely. stopping fire and other high temperature heat transfers doesn't require much R to have huge effects. To do the same at low temps, you need to try a lot harder.
greeninsulationUser is Offline
04 Jun 2009 09:18 AM
Crete-Heat is an all in one product has 3" on center fasteners to allow for quick tube installation. compressive resisance @10% deformatin (ASTM C165-00) is 25 psi/3600 psf. Perm Resistance as per ASTM E 96-00 test is . 51. Will give you a stable R-10 and does not need to be adjusted for age. It saves time, doesnt need poly and holds the tubing all at the same time. To find out more see at www.GreenInsulationProducts.com
05 Jun 2009 08:53 AM
Posted By jonr on 06/04/2009 8:28 AM
> Mylar. The great thing about this is it does not need an air gap to stop heat transfer because it is non conductive of any kind of  energy
Snake oil.
Also be careful of someone who sells you a .01 inch thick sheet of plastic and says it is R4 *per inch* (hoping you will forget to divide by 100).
No kidding!?!
The weird thing is, some people who write that kind of stuff actually BELIEVE the hype!
Go ask NASA and the fire chief? (Yeah, go ask the fire chief how the fire hazard is reduced by installing radiant barrier under concrete slabs. )
People who actually measure stuff have much higher cred, and damned few of them are insulation installers.  There's a reason ASTM C177 & C1158 tests were invented...  Do the math- the rest is BS. Radiant barrier is one of the most mis-applied & overhyped insulation technologies out there (but some of the foam guys are trying!)  Radiant barriers have their places, but none of those places is in direct contact with both the radiating & absorptive elements.  (But on either side of low-density fiberglass, yes, it makes a measurable difference.)
Radiant barrier, ie reflective foam insulation indeed to have their place, as a distributor of them, I totally agree, they they do not belong underground. I sell outdoor wood furnaces and even tho I sell MicroFoil reflective foam insulation, I refuse to use it as a product that is made into a insulated water line to carry the heated water from the outdoor furnace to inside. I do not believe foil belongs underground.
Radiant barriers are extremly effective in stopping radiant energy but there is no sun ( no radiant energy ) under ground. Now a hot roof in Florida is the perfect application for radiant barriers and it will save a trememdous amount of heat from entering buidings and save a lot of energy costs in cooling, prolong the life of a/c units, have a cooler enervironment etc. I have lots of information of the benefits of radiant barriers on our site at www.GreenInsulationProducts.com
People Online People Online: Visitors Visitors: 281 Members Members: 0 Total Total: 281
