what to do with crawl space?
Last Post 04 Nov 2009 08:07 PM by quailrunner. 1 Replies.
dragonUser is Offline
31 Oct 2009 12:55 AM
The builder for my house is putting down a slab with a crawl space of 30" or so before the floor. There are no floor joists, but a bunch of 20-30 inch adjustable steel post like things. It's basically a raised floor above a slab. Can't say I understand the pros/cons of it, but it is very common here in Japan. Please help me understand the choice here I have. Slab vs stable up in the crawl space vs a sub floor install like warmboard or a DIY sandwich install. If you have a choice, which would you use. It is not that cold here, about like north california or souther oregon. It is very humid though. Installing a staple up system like the q-panels from warmmfloors.com is a snap with this crawlspace, but then doesn't the system have to warm up the whole 760 square feet of 30" of crawlspace before heating the floor and upwards. Not to mention the heat loss out the crawlspace sides and slab downward, it seams a hugely inefficient way to approach crawlspaces. Above subfloor options like warmbord or diy seem so much more efficient but so much more work. Please help me understand.
quailrunnerUser is Offline
Someone w. more experience will likely reply w. specifics, but my own experience says that you will have to have the crawl space insulated in any case or your system will lose heat downward (stapleup or above-subfloor option doesn't make much difference, I believe).
People Online People Online: Visitors Visitors: 187 Members Members: 0 Total Total: 187
