Velocity of fluid in radiant tubing
Last Post 07 Nov 2009 09:27 PM by jonr. 2 Replies.
Glen WUser is Offline
05 Nov 2009 12:35 AM
Is their an ideal flow rate or should I just measure EWT and LWT . of 250’ half inch pex loops?
05 Nov 2009 08:33 AM
what are you trying to do?
typically, a temperature drop across the loop of 10 to 30 degrees is used, with 20 being an arbitrary residential max. however, supply temperature restrictions/requirements, balancing between zones might change the flow rates you are looking to achieve.
Thermally, more flow is better and I wouldn't cause any flow restriction that wasn't required for balancing.
People Online People Online: Visitors Visitors: 262 Members Members: 0 Total Total: 262
