Posted By CherieK on 11/14/2009 5:32 PM
I like the idea of the radiant ceiling - one question. Heat rises, does this really heat down to the floor? Or is the upper part of the room warm and the floors a lot cooler?
Hot air rises. Heat goes from hotter region to cooler region, regardless of direction. In ceiling radiant the heat radiates from the ceiling to everything below it. The floor, furniture, people, etc., all absorb the radiant heat and feel warm. The air in the room is warmed by all the floors, walls, furniture, etc., warming the air that contacts them. The only downside I've ever really heard about ceiling radiant is a person's legs may feel cool when they are underneath a table or desk. That's because the table blocks the radiation from the ceiling to the legs. If the system is not designed correctly, and the ceiling is allowed to be too hot, you can have a situation of "hot heads."
Radiant ceiling is a great way to go, but it must be designed properly. I was going to do that in the house I recently finished but opted for a lower cost, high efficiency, air-to-air heat pump system.
