Finishing basement, thinking of converting FHA to radiant for first floor and basement also?
Last Post 01 Jan 2010 06:01 PM by Egghead2004. 21 Replies.
01 Jan 2010 10:41 AM
so your heat load calc was too high? what does "better than planned" mean?
Egghead2004User is Offline
I should say better than expected. I guess the heat load estimate may have been a bit high, but I am also running 140 degree water. Next fall I'll add that outdoor reset mixing valve and see how low I can run the water at. Don't forget, this is just the first floor of a 2 story cape, so there is heated space above.
I guess I rolled the dice a bit by trying this, but we've had a couple of fairly cold nights below 10 degrees with wind, and it works wonderfully. The trick will be next year to see how low I can run the water temp at.
People Online People Online: Visitors Visitors: 205 Members Members: 0 Total Total: 205
