Well I've just recently had my Triangle Tube Solo 60 (LP) and Smart 30 Indirect installed and fired up. The first couple of weeks everything was smooth and fine. A couple of weeks ago I jumped out of my bed at 2 AM to a loud noise that I can best describe as a mix of a whistle, humming, pulsating noise, shop vac almost like a train whistle or warning siren. It sounds bad inside, but even worse out the concentric vent! Almost deafening!
The unit isn't shutting down or giving an kind of error messages.
I thought maybe the condensate drain pump might not be functioning properly causing a drainage issue, but I'm not sure.
I took the the door off the unit and you can hear the whistle coming out of the down facing PVC pipe located in the middle of the unit.
I choose this unit over a similar sized Munchkin because it was supposed to be the best and most trouble free in this size. However this is making me a little nervous.
