hi to all!
What a great site! My wife & I are building a house next year, & I have been posting in the geothermal & SIP forums. We're getting closer to figuring out our plan. We are definitely doing geothermal heat, leaning toward SIP construction. The house will be approx 2000 sq ft walkout ranch with another 1000+ finished in the basement, so I'm trying to figure out the best way to heat the basement. I'm pretty sure we're going to do forced air heat throughout the house. As much as I like the idea of radiant heat, I don't think our budget can support it. My understanding is that we would need all of the ductwork anyway for the A/C in the summer. Because we are building a very tight house, we will need an HRV also, which I think also relies on ductwork. For those reasons, my understanding is that we would have to install basically the same system that would would normally install for forced air, PLUS the radiant system.
When it comes to the basement, though, I'm wondering if it would make sense to do radiant heat vs. additional ductwork for forced air heat. Can anyone ballpark the cost differential between the two, if we did radiant only in the basement?
