Posted By cfoster on 12/20/2009 9:08 PM
Thanks everyone, and sorry -- I really should have add more details.
It's an ICF home (3" insulation / 6" concrete / 3" insulation). New construction. Triple glazed fiberglass windows. The two front rooms in question are corner rooms. Both have one 4x4 window (east facing), and one room has an additional two 2x2 windows (south). 176sq.ft. of exterior wall, 120 sq. ft. of roof.
The radiant floor input temperature is now around 95'F and returns at 80'F. I've increased the flow for the front two rooms to 0.6gpm. I've reduced flow in the other rooms to about 0.2gpm.
I've been wondering: if the attic insulation were thin over the outer walls, would the cold bleed through the concrete from the top (and create cold walls)? I'm hoping a direct inspection of the attic insulation will tell me what's going on. (I can just carefully wade through loose-fill insulation to get to the front rooms, yes?)
The exterior walls are noticeably cooler than other walls so this is my best guess right now.
I'll see if I can track down an IR sensor. Thanks!
-Colin.
The 6" of insulation on the exterior walls adds up to ~R24, then you have the windows, which are guaranteed less than R24, so your average insulation over the walls is likely ~R22-ish.
Your attic is ~R40, and you're wondering if thin spots in the attic where the coolth is entering, conducting down the concrete and sapping heat from the room through the ~R12 of interior side wall insulation? Perish the thought! Even if it were half-thickness (R20) over the entire attic, the wall's heat loss will still dominate, since the walls have ~50% more area, with an average R value comparable to the half-thickness attic.
The problem is not attic insulation unless it's out & out MISSING (not just thin, or with some gaps), and over a significant portion of the area. This could be determined easily with the a ladder and the palm of your hand. Otherwise, bump the temp 5F at a time until it keeps up.
Unless your ceilings are rated for the dynamic loading of a walking person (and I doubt they are), don't even think about walking on it. If the joist tops are exposed (and I'm assuming they're not) you might be able to walk out along the tops of the joists, but it should be obvious if there's missing insulation. If the roof is ventilated at the soffits without proper chutes it's possible that you'll get some wind-driven thinning at spots, but it would have to have made huge drifts scrubbing other spots bare to have a large effect on the room's heat loss.
