I live in vt and plan to put a steel roof on this year and have found a company that sells steel perlins that allow you to snap the pex tubing in. I contacted them they have one customer that has install in vt but has not tested yet. Any one out there that has tried this in cold climate states. This is the add from e-bay it is a metal perlin with a snap in pex area they install reflective product between the roof deck and steel roof
Liberty Solar Roof Purlin
Creates Hidden Roof Solar Collector
LESS THAN $2/square foot!!This do - it - yourself solar collector for hot water can collect up to 90,000 BTU per day!Contractors Welcome!
The Liberty Solar Purlin is used to collect the sun’s energy in
the form of hot water suitable for domestic hot water, space heating, or
to power a solar chiller for air conditioning. The purlin is the same
size as a 2x4 wood purlin and can be structurally integrated into the
building. Because a re-roof or new roof installation often uses 2x4 wood
purlins, you can replace the wood purlins with the new solar purlins
(1.5” x 3.5”) and use them to heat your hot water.
The System:
We
recommend placing foil-faced insulation down before screwing the solar
purlin to rafters or to an existing roof or deck. This reflects the heat
into the 1.5” air space to be captured in PEX tubing that snaps into
the solar purlin. The flexible pex tubing snaps into the rounded slot in
the top of the solar purlin for optimum heat transfer from the metal
solar purlin to the water. The roofing is then screwed onto the purlin
in the wide area designed for attaching the roofing or decking. When the
roof is warmed by the sun, the solar purlin transfers the heat to the
pex tubing carrying water or glycol (in areas where freezing
temperatures occur). The one square foot can collect from 150 - 300
btu/day.
The Advantage:
Low cost of installation
It is hidden from view and blends into any roof structure.
It won't be damaged by hail, vandalism as other solar collectors that use glass or breakable items.
It can be used with a large variety of roofing systems: steel, slate, asphalt, rubber, and other roofing materials
Protection from wind, hail, and vandalism
Long life using proven industry standard products
Turns every roofing job into a solar hot water heater job
Reduces reliance upon foreign oil
After installation, heats hot water with free energy from the sun.
Designed & made in the USA (Knoxville, PA)
In
utilizing the energy from the sun by collecting it and turning it into
useable energy, the most efficient process is to collect the heat
(thermal energy) from the sun. Even using our high efficiency heat tube
systems, the cost is high and payback will be 5 - 10 years for many
applications. Here at Liberty we have been researching and designing
new machines for many years. From our very first downspout machine to
the many machines that have followed we have always sought to bring
COST EFFECTIVE solutions that can be readily used by contractors and
installers of systems.
In our
quest to provide the most cost effective solar system, we have a new
machine that can be used to capture the heat absorbed by an entire roof
system. Even in our northern Pennsylvania, we know that roofs collect a
lot of heat. In the summer, roofers start early in the morning, and if
they are laying asphalt shingles, they need to be off the roof by noon
or the shingles get so hot that they can burn their hands or ruin the
surface of the shingles.
Until
now, home owners and contractors had no choice... they had to install the roof and then
later add a costly solar system. Now we have a new machine that can
make any roof a solar collector with very minimal cost on a new roofing
job. It can be used on steel, steel r-panel, standing seam, tile, and
even asphalt shingles. Our roll-former can make a solar roof purlin
that allows pex tubing to be quickly be put in place.
The
heat that is captured on sunny days can assist in heating water,
heating a building with radiant in-floor heat, or even cooling a
building with a cooling tower to take the energy collected and drive an
air conditioning unit.
Here is what you get with our system. This system is designed for a 10 x 30' of roof area.
Included in the above price is:
140' of our patent pending solar purlin profile ($1.60/linear foot)
300' of 1/2" Pex tubing to snap into the solar purlin as you can see in the pictures.
400 sq. ft of reflective foil insulation (seen underneath the solar purlin.
What you will need to complete the collector is:
1. Several 2x4's to go around the outside of your collector area (nails, screws, etc).
2.
Steel roofing you can buy locally. (for a 10' x 30' area you need 10
pcs of 10 'long x 3' wide steel). You can use a variety of different,
but dark colors are more efficient.
3.
After the collector is installed you will need some pumps, etc. You can
go as automatic or manual as you desire, and you can call us at 800-806
7109 to find out more information. We have a complete supply of heat
transfer tanks, pumps, electronics, etc.
Installation of the solar collector is easy.
1. Staple the foil insulation to your decking, rafters, or old roofing.
2. Nail your 2x4's around the perimeter of your solar area.
3. Screw your solar purlins in rows like normal purlins in parallel lines horizontally.
4. Snap the pex tubing into the solar purlin leaving room to go from the roof area towards your source and destination.
5. Screw the metal roofing down, marking lines so you don't screw through the pex tubing.
Once your collector is in place you can hook a pump to pump domestic water, swimming pool water, etc. through it.
This system is save, hidden from view, keeps your attic are cooler.
For larger systems you can email us at [email protected] or call us at 814 326-4121 for custom sizes.
