Hi, We provide a lot of floor panel systems, Yes you can place the walls later, keep in mind the pipes, it is obvious but keep them in mind, further If you use a floating wood floor or the like this is optimum, no nails! One zone/thermostat is fine. It is not a bad idea to map your cabinets, refrigerator and pantry areas out ahead and skip the pipe in those areas. If you need assistance we are glad to help as needed, Dan |
