Basement heating solution
Last Post 02 Feb 2010 03:16 PM by kicksave29. 4 Replies.
kicksave29User is Offline
19 Jan 2010 01:43 PM
I have just begun a 1100sqft basement remodel.
First step Radon Test. Came back 12.4.
So I will have a mitigation fan hooked up to the currently being installed drainage sytem.
Next Step is a vapor barrier for the floor. I am going with Delta FL membrane.
Once the membrane is down I was considering a radiant heating system such as raupanel, quicktrack or warmboard. Anybody have any suggestions?
geodonUser is Offline
01 Feb 2010 10:15 PM
I have used the warm board and it is pricey but its performance is exceptionaly good, be sure to insulate under what ever you put down
BadgerBoilerMNUser is Offline
02 Feb 2010 06:28 AM
Warmboard is a fine product but would be an expensive misapplication in your case.
02 Feb 2010 08:57 AM
If the slab is not insulated, I typically recommend Roth panel if floating floors or tile can be used.
So any suggestions? I was looking more into Zmesh, can't seem to find the cost anywhere. The hydronic systems are still an option but Zmesh seems to be a very quick and easy install.
People Online People Online: Visitors Visitors: 337 Members Members: 0 Total Total: 337
