Decreasing the size of a floor panel
Last Post 25 Jan 2010 05:02 PM by jbaron. 6 Replies.
jbaronUser is Offline
24 Jan 2010 01:49 PM
I'm going to be installing radiant floors in two bedrooms using ThermalBoard. The bedrooms are on top of one another, and the lower one is over a basement. The upper bedroom is slightly smaller, but the heat loss is higher, because of a bit more glazing and the surface area of the roof, primarily. Both bedrooms will be using the same temperature water. If I install the ThermalBoard on the entire floor areas of both bedrooms, the lower bedroom, having a lower heat loss but more surface area, will cycle more often. It seems like I could take a leap, trust my calculations, and omit some of the ThermalBoard in the lower bedroom. What do you think? Jeff
25 Jan 2010 08:40 AM
you could probably balance the flow down as well.
that said you probably don't want to zone rooms on different floors together. that's a bad idea.
25 Jan 2010 09:44 AM
Rob,
I'm not going to zone the rooms together; sorry that I gave you that impression. My only real question is "is it worth it to decrease the amount of tubing on the floor to get what I think will be a more consistently-on zone? Or, shoudl I take my on-off cycling and not worry about it?"
Jeff
25 Jan 2010 09:45 AM
use a floor sensor and forget about it :D
or flow balance. I would not do partial floor coverage.
25 Jan 2010 09:59 AM
OK THEN!!! Thanks Rob. What kinds of thermostats would be useful here, then?
Jeff
25 Jan 2010 01:23 PM
we like the tekmar 508's as a good, standard duty thermostat with logic and a floor sensor input.
Thanks Rob.
Jeff
People Online People Online: Visitors Visitors: 321 Members Members: 0 Total Total: 321
