Radiant Heat Retrofit (Long)
Last Post 11 Feb 2010 04:04 PM by Jeff from KY. 5 Replies.
Jeff from KYUser is Offline
10 Feb 2010 04:16 PM
 Hey guys, I’ve been reading the older threads and they have already answered a lot of my questions. If you don’t mind, at this point I’d like to lay out some of my project thoughts and solicit opinions from you. I’ll begin with a description of the house and some of my thoughts and see where it goes.
We live in far western Kentucky in a house that we designed and built ourselves 20 years ago. The house is an earth sheltered, passive solar design, roughly 55’ x 24’. Long dimension faces due south. The south side is 2”x6” stick framed construction with R-19 fiberglass batt insulation and lots of double pane, low e windows (probably 1/3 – ½ of the south wall area). The north side of the house is set into a hillside so that most of the back side of the house is underground.  The back part of the house is 10” poured concrete walls with 2” of rigid Styrofoam insulation on the outside (between the walls and the earth). The floor is concrete slab on grade. Before pouring the slab we put down 6”-8” of sand and then 1” of rigid Styrofoam (probably should have used 2” but that’s spilt milk now). We covered the poured concrete slab with ½” brick pavers. Roof is comprised of wood and foam structural panels with an R value of 25.
The inside is an open design using post and beam construction with only the bathroom and one back bedroom (northeast corner) walled off from the rest of the living space. The central portion of the house (20’wide by 24’ deep) is two stories tall with the kitchen in the front 2/3rds and the bathroom and utility room behind the kitchen, on the north side. Above the kitchen and bathroom/utility is a bedroom loft that is roughly 16’x14’ and open to the ground floor (kitchen) on the front. Ceiling is cathedral style (no attic space) with the finished side of the structural roof panels providing the ceiling. On the west and east sides of the central section are the TV and spare bedroom on one side and the living room on the other. These side sections are one story.
We have always heated with a combination of the passive solar gain and a cast iron, airtight wood stove. The wood stove is located on the west side, in the living room. Bathroom and the back bedroom stay a little cool, but the rest of the house is quite comfortable. Passive solar works well. Today for example it is in the high 20s (F) with gusty winds, but full sun. I’ve had to damp down the wood stove almost completely to keep it from getting too warm in here.
We now have two factors coming together that led me to asking for opinions here. My wife and I are now in our 60s and heating entirely with wood is getting to be a bit problematic (cutting, splitting, hauling, etc.) and we want to come up with a supplement/alternative to the wood stove. Second, I want to put down an overlay floor in the central, kitchen area (~320 sq. ft.). The plan is to use 1”x2” stringers on the slab floor, standard 5/8” subflooring and then either vinyl or linoleum.
So, for my questions (finally, this guy does go on, doesn’t he). I figured that if I am putting down the overlay floor wouldn’t it be make sense to put some PEX tubing loops underneath the subfloor (on top of the brick pavers) and add some hydronic radiant heat to the project? In my environment, would I need anything other than the tubing (e.g. fins or reflective foil) or will the large, insulated thermal mass of the floor be a plus (help to warm the whole space) or a minus (pull the heat down into the floor rather than radiate up through the new floor)?
I then thought that if I was going to install radiant heat in the kitchen, wouldn’t it make sense to put some form of radiator in the cool bathroom, mounted on the back, poured concrete wall, and possibly also a radiator in the back bedroom?
Since I haven’t done the heat loss calcs yet, I know I’m not ready to begin discussing system sizes or heat sources (though NG is out, not available here). However, I would love to hear opinions about the overall concept as it relates to my particular environment. Anyone want to jump in?
Thanks in advance.
Jeff
Paducah, KY
Eric AndersonUser is Offline
11 Feb 2010 11:36 AM
First  question is how many cord of wood per year do you burn now?  From this you can figure out how many BTU's per year you need to make up.
Second, What is the ratting in BTU's for the woodstove and do you ever have to run it full bore to keep the place warm?
To me the easiest solution is to replace the wood stove with an Nat gas or propane stove in the same location.  IF you want to keep the wood stove, adding a direct vent, sealed combustion wall furnace would be easy and quick.  You lose some efficiency over a boiler and radiant heat, but if your heat load is small enough, it might not matter to much.
Cleers
eric
11 Feb 2010 03:06 PM
In Paducah's ~4200HDD climate you can probably heat the place just fine with a propane hot water heater-combi system. Your design-day outdoor temps are probably low single-digits-F, but your "typical" numbers are quite modest, and in record-breaking cold you can fire up the wood stove if a water heater's modest output was being strained.
The thermal mass of the floor isn't a bad thing, but it won't be hard to control with the tubing in an overfloor situtation, WarmBoard (tm) style with thin-aluminum heat spreaders (necessary to avoid warm/cold stripes on the floor, and to get more heat out of the PEX and into the subfloor.) The thermal mass won't "pull the heat down" exactly, but will store and release heat whenever there's a temperature difference between the tubing and the pavers. The mass will give add a moderating affect on the floor temp but unlike embedded-tube slabs, won't much affect the response time of the system (which will be pretty decent.)
You might be able to pull it off with an electric HW heater and a heat exchanger, but that depends a lot on what your heat-loss numbers look like.
Like eric said, if your heat load is low enough the absolute efficiency doesn't much matter, but your peak output requirements still do. Still, even when it's not keeping up, radiant can be pretty comfortable, sitting on the warm floor with a pillow & comforter watching the shrieking winter storm outside your windows. Your high passive gain probably keeps the fuel use low, but the glazing represents a higher peak-load condition when it's a not-so-sunny 5AM and -5F outside. A propane stove or wall furnace where the woodstove now sits would put out more heat than a typical propane water heater, even if the radiant ran the show most of the time. The difference in combustion efficiency would be negligible, but as-operated there will be higher efficiency when there's more thermal mass to work on (as in the bulk water of the tank + the thermal mass of the floor.) On any propane appliance, avoid standing-pilot ignition, which can be a significant standby loss when you're not actively heating.
11 Feb 2010 03:17 PM
BTW: I neglected to mention- there's nothing in your radiant heating situation that would call for reflective foils, etc. On a really high-temperature water between the joist staple up configurations there is (sometimes but rarely) a rationale for radiant barrier, but most of the time it's uncalled for. (And never when you can't get at least a 1/2" of air space between the foil and radiating element.) Above the floor tubing delivers the heat with much cooler water, and you'd have to build it up to add the air gap, which would be silly.
It's probably worthwhile to put in strips 3/4" of XPS in the spaces between the tubing & stringers though. That'll add another ~R3.3 to the floor insulation increasing efficiency & enhancing response time. It doesn't have to be a perfect fit to have an effect.
11 Feb 2010 03:55 PM
Posted By eric anderson on 11 Feb 2010 11:36 AM
Eric, first, thanks for the reply. Here in Western KY no one sells wood by the cord, they sell it by the rick. A rick is what is also known as a "face cord", 4'x4'x16"-18". So a rick is roughly 1/3 of a cord. In a very cold winter we burn maybe 2-3 cords. In a normal winter, less then 2 cords.
Our wood stove is the same one that we installed when we built the house 20 years ago so it's probably not quite as efficient as it once was. New I believe the BTU rating was 40K-42K BTU. That said, if I ever crank the stove up to full bore, it can get uncomfortably warm fairly quickly unless outside temps are in single digits.
We REALLY prefer the radiant heat from the cast iron wood stove to any type of blown air heating solution. We have tried a pellet/corn stove and although it kept the house warm, for us, the moving air just wasn't as comfortable as a radiant heat source.
Cleers
eric
I'll do some research on sealed combustion wall furnaces. Thanks again for the input and ideas.
Jeff
Paducah, KY
Posted By Dana1 on 11 Feb 2010 03:06 PM
Good point on using the wood stove to supplement the hydronic radiant. That was exactly what I hoped to be able to do; use radiant for most of the time and then fire up the wood stove when it's really cold.
Thanks, dana, very helpful info. I'll have to digest and then finish my heat loss calcs. I am sure that if I decide to proceed with the radiant system I discussed above, I will have many more questions.
Jeff
Paducah, KY
People Online People Online: Visitors Visitors: 337 Members Members: 0 Total Total: 337
