Radiant Heating
Hot Water Tank Connections, Side or Top?
Last Post 17 Aug 2010 05:58 PM by
kicker_92
. 3 Replies.
Oldest First
Most Recent First
Prev
Next
Author
Messages
kicker_92
16 Aug 2010 01:43 PM
For a radiant system using a domestic hot water tank, whats the differance in using the side connections vs the top connections on the tank? (closed system)
I'm assuming that theres a reason that most radiant hookups are on the side, but will there be any harm in using the top connections instead?
kicker_92
17 Aug 2010 05:19 PM
I know a bunch of you on here have used hot water tanks for small heating applications. So which ports did you use, Side or Top? and why?
BadgerBoilerMN
17 Aug 2010 05:42 PM
The dip tube and energy saving traps (often on the hot and cold fittings) and present an unknown pressure drop.
Water heaters with side taps have no pressure drop and are marked "Suitable for use as space AND water heating".
The more you get outside accepted and common practice (without professional guidance) the more risk you take; both financial and bodily harm.
kicker_92
Thank you, I was unsure if both connections had the same dip tub arrangement.
I will use the side connections for our setup.
Radiant Heating
Membership:
croccohvacusa
People Online:
